Jack in Wilmington
If you see the three black circles at the bottom of the rack, they actually are the ends of three metal rods that extend from the front to the back to give the whole unit strength. The bottom glass shelf doesn't touch those three rods. The glass up top that holds the turntable is thicker, but who wants their amp on the top shelf. Plus I'd probably bust a nut lifting it up there. Like Mike and Joe said, the bottom shelf looks like the best place.Jack, If the bottom shelf breaks, replace it with wood. It may be a conservative rating, does the bottom have more support than the middle ones?
I thought about that Mike, but I'd have to pay for overweight luggage.Actually, come to think of it, the best place to place your new Pass Labs amp is my house!![]()
I'll cover that. No problem. I will send you weekly updates on how great it sounds.![]()
I have two X600.5 amps on the bottom shelf (4" solid maple), with a combined weight of 300 pounds. The biggest problem is heat. There is an 8" clearance to the next shelf, and the temperature on the next shelf gets to 81 degrees. I am going to rearrange gear, and move the next shelf up another 4".
I was was going to get a single wide rack for the other gear, and put the amps on platforms on either side of the rack, with nothing above the amps. However, I realized that was a disaster waiting to happen, since it would be easy for someone to spill liquid onto an amp. So scratch that idea.
I have two Accuphase Class A amps on single amp stands and they never have been much more that warm to the touch. I took my Quadraspire amp stands that they set on, they are slotted for air flow, and added columns and a shelf on top for my power supplies. The amps are open all the way around but on top there is only 3" of space between the top of the amp and the next slotted shelf . This made the amps so hot you could barely touch them . I had to go back to the single amp stand with nothing on top. My point is heat is required for your amps to operate properly but if they are getting too hot then you could be shortening the life of your very expensive amps.
Jack,
I will be driving thru Wilmington about 5am on Sunday morning on my way to Hilton Head.
I think if you place it by the front door, that would be the best spot.
Can't wait to hear how it is driving those Danes.
If it's not there, knock and I can at least refill your coffee. Every time I hear a big truck go down the street, I get excited. I'm already warming the wife up with talk of a preamp. I was explaining that the amp is the muscle and the preamp is the brains. She wanted to know why I didn't get the brains first. I explained it to her and she understood. This is good, especially that she asked about it.
