mep
- Dec 4, 2013
Part 1 of my VPI Avenger review can now be read on PF: http://positive-feedback.com/audio-discourse/vpi-avenger-turntable-part-1/
Nice review Mark. Love my VPI table. The comment about the clamp was odd for me. I didn't quite follow. But regardless, nice review. Dynamic is definitely a good word for it.
About the clamp, do you use it every time you play an LP and have no issues landing it perfectly or are you referring to something else I said about the clamp?
I use the clamp only on badly warped records. But I've never had any issues when I do use it. I think part of the reason might be because my stand is so low, so I can get right over top of the TT. I can see how it would be a challenge if the TT was on the top shelf.
For a small warp in the album, I find the unipivot actually tracks pretty good.
OK. The clamp is intended to be used on every LP, not just warped ones. I have seen people at shows just place it on the platter and leave it there because they didn't want to be bothered with setting it in place on every LP. If you just place the clamp on the platter before you put a record on and leave the clamp in place, you do get some benefit from the flywheel effect of the heavy clamp. If you haven't tried that yet, you should if you don't want to use the clamp on every LP.
Makes sense, but it's a big and clunky to use on every LP, IMO.
Thanks guys! I have never reviewed or heard the SME Model 10 so unfortunately, I can't make any comparisons for you.
Unfortunately no. I just haven't had the opportunity yet. I obviously believe in SME as I own an SME 312S arm as well as an SME 3012-R arm.
Thanks Mark! I'm looking forward to hearing the other versions.
