I've often wondered, on a psychoacoustic level, whether the brain prefers analog because its a sine wave, whereas digital is a square wave and requires the brain to do more "work" filling in the blanks.
The digital people will tell you that once the analog sine waves have been converted by PCM into square waves and then back into sine waves at the "A" portion of the D/A converter, there is no difference. Those with a set of ears and a decent analog rig know different. Some people like twice-baked potatoes. If you are an analog first audiophile, you don't want your analog converted to digital and then converted back again to analog.
I have a substantial investment in my entire system, including both the analog and digital front end gear. I've read some other high end system owners say that the only way to be able to enjoy your digital source is to not listen to analog. So for a couple of months I decided to try it and only listened to my digital source which includes many high-res titles in both PCM and DSD formats. I was able to enjoy my digital source and thought the system was sounding very good. Then when I decided to spin some vinyl again I was astounded by what I heard. I was immediately struck by how much more fluid the sound was, with much better textures along with a captivating sense of space and realistic decay. What I experienced was not a subtle change by any standard, it was a dramatic improvement that was an order of magnitude more realistic sounding than my digital playback. Of course with analog you do get a few pops and clicks depending upon the condition of the vinyl, but any such noise is insignificant to me compared to what I gained versus digital playback.
That was an interesting article. Thanks for posting.
I compare listening to vinyl with a colonoscopy. I put it off for as long as I can. The prep work is barely tolerable. The proper amount of sedation is important because you can only relax for about 20 minutes before you are forced to get up. When I am finished I am very hungry and thinking I will push the next one off as far into the future while listening to others say how much they enjoyed it.
Why is there a chalkboard in the dentists??
Ok, so what is considered a "decent" analog rig? Let's say under $5k. As I understand I'd need a TT (tonearm, cartridge), phono stage, a couple of power cords, phono cable, a set of IC's?
