I wish there was full disclosure on master recordings and master transfers also.
In other words, you can't tell at all, since Brothers In Arms's digital recording system is substantially worse than pretty much any in use today.Buy music that you know was originally mastered and recorded on tape....older stuff. No guarantee, but if you buy from known reissue labels, they will be true analog the majority of the time. You can usually tell digital to vinyl from analog to vinyl..the digital being dry, strident with a collapsed sound stage....one exception Brothers In Arms...Dire Straits.
For newer vinyl pressings, how does one do the research before buying vinyl to determine if the vinyl is cut from a CD master versus the high-resolution master?
The Rolling Stones DSD vinyl is very nice.
+1.
Since the vast majority of new recordings are digital, we can assume new vinyl pressings are cut from the digital masters. Blasphemy!![]()
My post was more a point of logic than anything else; if the OP is looking for a way to identify LP's cut from CD masters, then the suggested discrimination characteristics aren't very useful if an LP cut from an old, very "digital" CD master lacks those characteristics. So on to more constructive suggestions.Not true. It just so happens some LPs cut from digital files sound pretty damn good (Live at the Cellar Door is a recent example though the original source was analog tape). Listen to Donald Fagen The Nightfly and you can tell it's a digital LP.
+1.
