M2wason
I spoke to Chuck at McIntosh about this and he said it is perfectly okay to separate the biwiring and use both 4 and 8 ohms tap on the Mac amp since it has the autoformers. He said if you are lacking bass, connect the lows on the 8 ohm tap and highs on the 4 ohm tap. He also said that you can't do this on another brand amp because it doesn't have the auto former. Has anyone done this, if so, what difference did it make.
