USBdisruptor
Audiophiles report being either “happy” or “very happy” using clean USB power products with dozens of DAC's at all price points. (Note: the below reports are from USB Disruptor customers, a clean USB power solution.)
Antelope DAC
Apogee Groove Black
Arte Forma DAC
Audioengine D1
Audioquest Dragonfly Red v1.0
Aune T1 Mark II
Ayre Acoustics QB-9
Ayre Codex
Bel Canto e.one c5i
Benchmark HDR1
Bryston BDA 2
Cambridge Audio Azur 851C
Cambridge Audio DacMagic
Cambridge Audio DacMagic Plus
Chord Mojo
Chord Qutest
Denafrips Ares II
Emotiva XDA-2
Exogal Comet Plus
FiiO Olympus 2 E10K
Grant Fidelity TubeDAC-11
iFi Micro iDSD Black
iFi Pro iDSD
Korg DS-DAC-10R
L.K.S. Audio MH-DA004
Maverick Audio D1
Micromega MyDAC
NAD M51
NuForce DAC (unknown type)
NuForce uDAC5
Oppo BDP-105D DAC
Peachtree (unknown type)
Peachtree Nova
Pro-Ject DAC Box S2+
PS Audio DirectStream
PS Audio NuWave
Schiit Gugnir multi bit
Schiit Gungnir (old version, but USB gen 2)
Schiit Modi 3 multi bit
Schiit Modi Uber
Schitt Modi (original version)
Schitt Yggdrasil (latest version)
SMSL D1
SMSL M8
SMSL M8a
SMSL M9
Stax SRM D-10 dac/amp
TEAC UD-501
Topping D10
Topping D30 – “Since the Topping E30 dac is so affordable, measures well and has gotten good reviews across the board, I just wanted to report the astonishing improvement that the Disruptor makes when it is used with the E30. Honestly, it is amazing!” – customer quote
Topping D50
Topping D50s
Topping D90
Topping DX7
Wadia 121
Wadia 151 Power Dac Mini
Wyred4Sound MINT
The problem:
Most computers are just not optimized for high resolution audio streaming.
The USB standard allows for line level voltage to swing about 5%. This sloppiness can cause problems with sensitive electrical devices like your USB DAC. The technical outcome of poor line level power regulation is ripple voltage, which is basically electrical noise, and this could impact the way your DAC behaves.
Adding to the problem is USB cable design.
The mass of USB cables on the market today, audiophile or not, could leak computer noise to your USB DAC via things like the metal mounting hardware of the USB cable. This may allow more electrical interference to work its way into the USB DAC. Even the physical proximity of the USB cable power wire to the digital signal lines, within the cable itself, could impact performance, hence the availability of very expensive audiophile USB cables that separate the power wire. Those cables solve only part of the problem.
Solutions:
Providing clean power to the USB line with an external supply for the USB cable, and separating the digital lines from the power lines inside the USB cable reportedly improves USB DAC performance.
Users of clean USB power solutions report the following observations:
“The beautiful overtones of instruments and vocals became organic and palpable not only aiding in the overall quality of the sound but also its profound impact on the sound stage. Micro dynamics are delivered without blurring. Additionally, the Disruptor clarified the bottom end by providing impact and additional weight with a sense of great agility and speed.”
“An immediate and obvious improvement. Better detail and a sense of darker space between the instruments. Vocals are more articulate without losing any emotion.”
“It lowers the noise floor and instrumental textures and stereo separation is better, a bit more relaxed analog presentation if you will.”
“It does indeed make digital sound more analog!”
“When I play classical music now, it might be softer at the setting I usually start at, but when I turn it up, it still sounds like music, and it blossoms. In the past, it would start out louder, but when I turned up the volume, I’d get so much hash, that I couldn’t turn it up anymore.”
“The soundstage exploded in front of me, deep and wide with a new found clarity and instruments seemingly floating about the soundstage with very nice separation too. Articulation of vocals was quite telling now as well, I ended up listening very late into the night and didn’t want to quit!!! ….. I find the dynamics appear much improved now as well like a clean window VS a dirty one.”
“More tone, more body and spatial characteristics.”
“I installed them in my system and was amazed at the improvement right out of the box. My wife (not an audiophile) was up on the second floor at the time, and commented on the improvement (unprecedented for her)! Today, listening to Beethoven’s 9th Symphony, she told me she heard instruments (horns) in the background she had never heard before (again, not an audiophile) and she got “goosebumps” from listening!”
Antelope DAC
Apogee Groove Black
Arte Forma DAC
Audioengine D1
Aune T1 Mark II
Ayre Acoustics QB-9
Ayre Codex
Bel Canto e.one c5i
Benchmark HDR1
Bryston BDA 2
Chord Mojo
Chord Qutest
Denafrips Ares II
Emotiva XDA-2
Exogal Comet Plus
FiiO Olympus 2 E10K
iFi Pro iDSD
Korg DS-DAC-10R
Maverick Audio D1
Micromega MyDAC
NAD M51
NuForce uDAC5
Oppo BDP-105D DAC
Peachtree Nova
PS Audio NuWave
Schiit Modi Uber
SMSL D1
SMSL M8
SMSL M8a
SMSL M9
TEAC UD-501
Topping D10
Topping D50
Topping D50s
Topping D90
Topping DX7
Wadia 121
Wyred4Sound MINT
The problem:
Solutions:
