Upgrade Request for Remote
Jpainter4731
Usa
I use the remote much more than the app. There are about 900 songs in the playlist I keep active. Navigation is difficult using next, shuffle, etc. The remote contains an unused numerical keypad, which if operational, would permit direct entry of a track selection. Any possibility this could be worked into a future update?
Those buttons are reserved for changing input if the remote is used with Lumin P-series.
