BeerCan
I need a sanity check here. I am wanting to get back into tubes in one of my setups. Right now I am having pretty good luck driving my Focal 1038 with the Luxman 590ax
I want to make sure I don't make a mistake and buy an under powered amp. The Focal are 3 way with 5 drivers, 93dB 2.83v/1m 8ohm going as low as 3.1 ohm. Room is 16' x 30' and I listen at moderate to low levels.
Thanks
Thanks
