Systems
is there a spot for listing ones system(s)? I see some as a signature line but I can't seem to figure out how to do even that.
Go to "Settings" then scroll down the left side and find "Edit Signature". That's where you can put in your..uh, well, signature. Just list your system there and it will show up like the rest. Your limited to 500 characters including spaces though, so be compact. If you go over the limit it won't save it and close and it will tell you that you went over the limit.
