Bahtman
I know the recommended placement is 90-120 degrees, but what about the optimum distance between them?
I’ve looked and looked and all I could find was… ”They should be raised to a height of approximately six feet and should ideally have a minimum space of six feet between them, as well.”
I have two options available to me and would like some opinions.
1. I can locate the left surround at only about 80 degrees and 15 ft. from the mlp and the right side at the recommended 90-120 at about 13 ft. from the mlp.
2. I can increase the size of the area rug and get both at the 90-120 degree mark but then they’d only be about 6.5 ft. each from the mlp.
Getting a rug that big would allow me to run the wires from the AVR under it and to their locations L and R of the mlp but at an added cost of about $1000.00. (Rugs are costly here in Thailand and I’d be combining three to get the size I need.)
Additionally, given these parameters, would monopole or bi-pole work the best given your recommendation on 1 or 2?
It’s a large room, 22’ front to back and 35 ft. left to right.
I’ve got either Focal 926’s or KEF Q 900’s in mind using a Denon X4100W and Martin Logan Dynamo 1500 sub using a 5.1 setup.
Surrounds to be determined based on your opinions.
I know the Audyssey MultEQ XT32 calibration will help in whatever location I select, but what would be your choice?
Thanks in advance for all your help.
