Speaker placement and audio setup question?
Pdough
Florida
Hi,
I recently joined this forum but recognize many of your names from other forums. I'm new to hifi audio and usually don't contribute to the discussions but I really enjoy reading your responses and have learned quite a bit.
This is the first thread I've started. I need some advise on speaker and equipment placement in my family room. I need to decide whether or not to have built-in cabinets installed around the fireplace. I don't have a dedicated listening room so my family room will serve as my main listening room for 2ch and HT. My audio equipment which I'll hopefully be upgrading within the next year consists of a Marantz receiver and Goldenear Triton Two speakers. My upgrade plan is to move to separates but to continue using my current speakers.
I will try to attach a photo but here's a description of the room. It's 17ft x 16ft. The audio equipment and speakers will go along the 17ft wall on both sides of a fireplace that is flush with the wall. The fireplace is 5ft 3/4in wide. It's not quite in the center of the wall - it's 5ft 11-1/2in from the left side wall and 6ft 4-1/2in from the right side wall. The back of the room is open to the kitchen. The listening position will be about 12-13ft from the speaker baffle if the speakers are about 8in from the back wall.
Here's where I need your advise. I originally planned on having custom cabinets built in to each side of the fireplace. The cabinets were going to be about 4 x 3 x 2 ft (H x W X D). I was planning on placing the speakers next to the cabinets but If I go with this plan then I won't be able to place the speakers closer than 11ft 3in apart and that's if they are place right next to the cabinets. Also the cabinets will be between the speakers which I have heard is not the best idea.
Alternatively, I can have the cabinets made a foot more narrow (4 x 2 x 2 ft) which means the speakers can then be placed closer together - about 9ft 5in if placed right next to the cabinets. However, the cabinets will still be between the speakers.
The last option (which I am leaning towards) would be to get a free-standing audio rack and place it in the corner. That way I won't have any cabinets between the speakers and I'll have more freedom to place my speakers. The speakers could then be as close as 6ft apart or up to probably 12ft apart if necessary.
Is having built-in cabinets between the speakers suboptimal? Since my listening position will be about 12-13ft from the speakers I take it optimal speaker width should be around 9ft (I remember seeing a formula for speaker width which was 3/4 x distance of the listening position from the speaker)? For that reason, if I went with the built-in cabinets then the speakers would probably be too far apart?
I want to make the best decisions to optimize the sound. I look forward to your advice. Thanks in advance for the much needed help.
Patrick
Hi Patrick,
Why don't you include a drawing of your plans? I think it will be easier to respond if we have visuals. Anyhow I think the cabinets potentially might be nice diffusers. It is important to keep your speakers at least 3-4 ft away from the side and the back (even if the back is a cabinet).
Hans
