Silly Question regarding Frequency Response:
JCS123
Detroit area
OK folks, this shows off my utter ignorance of audio electronics, so thanks for indulging me here.
Say I'm listening to speakers or subs that play down to 16Hz being driven by an amplifier that is rated at 20Hz-20kHz, will I be able to hear (or feel) anything in the 16-20Hz range?
Thanks in advance for any and all answers. I'll be checking the responses on and off today, but right now its time to get ready for some football!
First, I don’t know how well the average ear can hear below 20hz, I’m sure some can. I think frequencies that low are mainly felt by the body.
When you see a rating of 20hz to 20 khz (referring to the limits of human hearing) keep in mind that there is still energy produced above and below this range, but the db level is lower, and they filter out at a certain db loss, to quote a range. (I see 3db frequently)
Assuming there is material that low (lowest note on a pipe organ) - only some pipe organs can reach 16hz - but that’s the lowest. My guess is the sub is rolling off far above that. Dual 18’s or bigger…maybe can get that low in room flat. The Clarisys Audio Infrasonic Generator which is part of the Atrium system can hit 11hz (flat, measured, in room). But it’s 9 feet tall, 3 feet wide and double sided with Neodymium type 52 magnets. It’s a special feat.
Theoretically, feel more than hear.
OK this is one real world rig that I had around 25 years ago:
conrad-johnson CAV-50 control amp: 33Hz to 15kHz
ACI Sapphire speakers: 64Hz-20kHz
ACI Titan Sub: 20Hz-250Hz
To clarify, in the above combination, I would not be able to hear or feel anything from 20-33Hz and 15-20kHz. Do I have this right, all other things being equal?
Thanks to your replies, I think I'm beginning to understand it a bit. I appreciate all of you who have responded.
Off topic but technically speaking — There are 2 pipe organs in the world that have 64’ pipes which could go as low as 8hz. But for practical purposes the vast majority of organs that exist only have 16’ pipes that go as low as 32hz.
Now that is very surprising. I have been under the impression that the pipe organ goes much lower than the typical 32Hz. I've always felt that I was missing a lot of the bottom end, regardless of how low the subs that I've had in the past go. Let alone live performances in a proper hall, even the sound of a live pipe organ in a church is something that I've never been able to attain in my own systems. Sounds like I need to get in to the church more often....
Definitely correct. Many times amp/other ratings are published like that as outside such a range the roll-off as well as specs like THD, etc. aren't as impressive so they often constrain them, e.g. 20Hz-20kHz whether other manufacturers publish much broader ranges as their test results outside the 20-20k range is much better than their competition.
In short, yes, they do and the statement above that the lowest possible being 16 Hz is true for many organs though far from true for all out there.
Forgetting for a moment synthesizer-produced bass popular in electronic pipe organs and/or electronic pipe organ stops as add-ons to traditional pipe organs and also forgetting all the great synthesized bass out there in prog-rock,
techno, electronica, etc.....
Human hearing is capable of hearing and distinguishing tones down to 16-20 Hz though that presumes good hearing without damage or disability. Otherwise, below a certain frequency the body feels vibrations. Below 16 Hz, it's all vibration and for the deepest notes (8Hz, etc..it sounds like a slowly oscillating phenomenon). Seek out the YouTube video that gives a full tour of the front of house all the way through the
back of house including "basement to rafters" and catwalks for the Midmer-Lash Organ at the Boardwalk Convention Center in Atlantic City, New Jersey. They have a great segment in there when a 64-foot pipe is sounded and they walk several levels to show the full extent of a (literally) 64-foot long pipe rank.
While it's true that there are only 2 pipe organs in the world with full 64-foot stops (Sydney Australia Town Hall and the Boardwalk Convention Center in Atlantic City NJ whose organ has been renovated and revived to its original full splendor),
Many organs in the world have one or more 32-foot full stops whose lowest fundamental frequency is 16Hz. The Cavaille-Coll Organ at the Abbey of St. Ouen in Rouen France is a personal favorite as its 32-foot Contra-Bombarde stop is one of the most highly regarded, earth-shattering/bombastic in the world (and it has two others!).
Great examples of this:
Kolner Dom (Germany): three 32-foot full bass pedal stops and one 64-foot "Resultant" stop (see below for explanation)
Passau Cathedral (Germany): has at least six full, working 32-foot stops. Also is the largest cathedral organ in the world.
Boardwalk Hall Auditorium Organ (Atlantic City, New Jersey, USA): The largest organ in the world, it is reported to have the largest number (nine) 32-foot stops in the world, counting only complete 32' ranks.
Wanamaker Grand Court Organ (Macy's Center City, Philadelphia, USA): Was the world's largest fully operational pipe organ prior to Atlantic City's being brought back to full life; it has seven 32-foot stops. Note: Tragically Wanamakers/Macy's has now been sold off and closed and the future of the organ is in transition.
The stunning/breathtakingly wonderful Newberry Memorial Organ at Woolsey Hall at Yale University: Has three full 32-foot stops (and one Resultant 64' foot stop)
United States Military Academy Cadet Chapel (West Point, New York, USA): This massive organ is listed as having seven 32-foot stops.
First Congregational Church (Los Angeles, California, USA): This organ is listed with eight 32-foot stops.
LDS Conference Center Organ (Salt Lake City, Utah, USA): This organ is also listed with seven 32-foot stops.
Cavaille-Coll organ at Saint-Sulpice (Paris): two full 32-foot stops plus one 32-foot "Resultant"
Cavaille-Coll organ at Abbey of St. Ouen / Rouen France: two 32-foot full stops plus one 32-foot "Resultant"
Cavaille-Coll organ at Notre Dame (Paris): three full 32-foot full stops and at least 1 resultant stops. Post-fire renovation build added/modernized the entire organ so the specs are lagging a bit behind.
There are MANY other examples.
I mentioned a "Resultant" pipe organ stop above. Even for organs with limited or no 64-foot, 32-foot and 16-foot bass pipe ranks, this is a common technique for achieving frequencies much lower than the largest pipe rank possible in the organ space, the build budget, etc...
A "resultant" stop is a way to effectively output the equivalent of a deeper stop by combining two other stops as noted below.
note: a Resultant pipe organ stop is sometimes listed as an "Acoustic Bass" or "Harmonic Bass" pipe rank though "Resultant" is much more common. It is a psychoacoustic illusion that results in the human ear actually hearing
the lower tone.
In summary:
A 16-foot full pipe organ rank can at most produce as its lowest frequency, 32Hz (one octave lower than 8-foot).
A 32-foot full pipe organ rank........its lowest frequency, 16 Hz (one octave lower than 16-foot).
A 64-foot full pipe organ rank......it's lowest frequency, 8 Hz (one octave lower than 32-foot).
A Resultant stop is the combination of two pipe organ ranks "sounding together" in that they are coupled and when a note is played, the primary rank and the harmonic rank are simultaneously played and the "resultant" note achieves the same frequency as a much bigger stop playing that same note.
More specifically, to create a 32-foot "resultant" full stop:
To mimic a 32-foot stop playing a fundamental frequency ("F")...
Combine a 16-foot stop and a 10 2/3 foot stop. The 16-foot stop plays the primary tone (frequency "2F") for a given pipe played. The 10 2/3 foot stop plays the harmonic, a perfect-fifth above the note produced by the 16-foot pipe. This is 3-times the fundamental frequency ("3F") played by the non-existent and desired 32-foot stop.
The human ear (or microphone) then perceives the "resultant" or "difference" tone as having been played and it is the difference of the frequencies: (3F - 2F) = Fdiff.
To mimic a 64-foot stop playing a fundamental frequency ("F"):
Combine a 32-foot stop and a 21 1/3 foot stop. The 32-foot stop plays the primary tone (frequency "2F") for a given pipe played. The 21 1/3 foot stop plays the harmonic, a perfect-fifth above the note produced by the 32-foot pipe. This is 3-times the fundamental frequency ("3F") played by the non-existent and desired 64-foot stop.
In short, the resultant is the 1st harmonic and equates to the pitch of the note from the pipe organ stop one is mimicking through this technique.
*If it's not obvious, I love pipe organs and like other genres that I own, I have a (somewhat embarrassingly) large number of albums collected and enjoyed over 3 decades...
No. Usually the low frequency rating of 33hz maybe what the amp is flat to. 33hz is not a brick wall the low frequencies just begin to roll off or drop at that point. So is very possible you will hear frequencies down to 20 hz and possibly fundamentally lower if a subwoofer.
Basically what Bones13 said just in a different way. Hope this helps some.
the lower tone.
In summary:
Wow, thank you so much for this exhaustive explanation and the examples! I am bookmarking this post for when I travel.
May I ask: in addition to Bach, are there any exceptional organ recordings that you can recommend? I enjoy all kinds of music.
OK, this clears things up considerably. Thank you, bones and everyone else who has responded!
Thank you very much! Yes, I can and will do. It may take a couple days to get the time to do that however I will post something soon. FYI, it may well be on a new thread.
In the meantime, as these are limited quantity and the recordings of this relatively brand new giant organ at the Lichen Basilica are not widely known, I'd jump on these. It is an amazing instrument made of several organs playable individually or in unison (like the Freiberg Cathedral organs in Germany) and has two 32-foot stops and one 64-foot Resultant. Grab these before they disappear. This instrument, the expansive space and recording quality are all quite amazing:
* I also wound up connecting with Dr. Michal Szostak last year for some great conversations (via email). He's a professor organ performance, history, etc. and is an amazing performer as well. He has a very few recordings out, all of exceptional sonics and performance quality. Two have tracks also recorded in Lichen Basilica. All of them have various instruments of different sizes from several countries:
The only place he sells is on eBay; here is his seller page:
I have these (found for sale on his seller-page). They are wonderful and also quantity limited. The 4th is a very interesting book with CD. (The first album cover shows one part (division) of the Lichen Basilica organ and is breathtaking).
He has one other album, "Prague Impressioms" that I also have which seems to no longer be for sale.
His website:
For all you elephants:
AI Overview
Elephants typically hear frequencies from approximately 17 Hz to 12,000 Hz, though some studies show a broader range, including as low as 3 Hz or 5 Hz. Their most notable ability is to detect low-frequency sounds known as infrasound, which fall below the human hearing range of 20 Hz and can travel for kilometers through the air and ground to facilitate long-distance communication.
Found a short video of the Sydney Hall Organ during a talk and demo. They have the 64' stop engaged alone in the first few seconds, then add the next harmonic up to accentuate the note. You can hear the deep rumble of notes 12Hz down to 8Hz in that massive hall...
