Puma Cat
So, yesterday I installed a single Sigma-X ground cable from Shunyata's newly-launched line of "X-Series" cables between my Lumin P1 and my source-component dedicated Altaira ground hub and....
Whoa!
Mind. Blown.
When I set up my fully-segmented Altaira system (dual-mono for the Constellation amp , i.e., an Altaira for each channel, L/R), and a third Altaira dedicated just for the Lumin P1 and EAR phono stage source components, and the cables required for it, I had standardized on the (original spec) Alpha ground cables for the key components (Lumin P1, Constellation amp, phono stage) for this segmented Altaira system.
I have to say installing just this one Sigma-X ground cable between the Lumin P1* and the source-component dedicated Altaira took the overall system performance s to another level, altogether. (*-and, once again, thank you, Lumin, for putting a proper ground terminal on your fine products; wish all manufacturers did this.
Mike's posted about the new Alpha-X and Sigma-X line of cables, and all I can say is that those breakthroughs in noise reduction, clarity, transparency, dynamics, resolution, etc. is fully carried through the the new "X-series" of ground cables as well.
I don't know what Caelin and team have have specifically done from an R&D perspective in developing the new new "X-series" of cables, but I can assure you guys, it truly is a breakthrough.
I'm sure Mike would agree.
Cheers, guys.
Whoa!
Mind. Blown.
Cheers, guys.
