I have no first hand experience with this combination of gear, but looking over the specs you should be using the Esoteric's Input 1 (MC/66dB gain) with the load impedance set as close to 30 ohms (recommended load for the RSP) as possible. You can then experiment with higher or lower loading impedances to tailor the sound to your liking and best overall system matching. Hope this helps and please let us know how it turns out! :audiophile:Correct settings for my Esoteric E03 phonostage using a Palmer 2.5 with PU7 arm and Koetsu Rosewood Signature Platinum MC Cartridge
