Sbooster for Ethernet switch
That was FYI only, and we have not tested it. My own speculation is that optical network (not Toslink) has the potential to be the best.
Hello Sir
Thanks a lot for the answer
I have tested the isolation rj45 switch , which works rather well
As you quoted , loads of people are satisfied with the FYI , but that tends to be difficult to arrange
Some subjective testing have been done and described in France
In the end , loads of people are using the "medical" switch
Regarding my system with the U1 + Melco , I should say that the difference is minimal with the purifying switch (placebo ?) , and may be this is because both the U1 and the Melco are well isolated (and the melco is connected directly to the U1)
Thanks again , and always a pleasure to see to quick answers .. and thanks again for the U1 which is really good (oups I'm off topic)
Cheers
