Alkyogre
These days I get my hand on a few intel nucs, with the idea to install my roon core on that nuc. Got 1 i3 5th generation and 2 i5s 6th generation. As roon endpoint I use a sonore ultrarendu together with a USB2 dac.
The reason for doing was an easy one, it was not about improving the sound quality, but having a machine that boots really fast, does not consume many energy and is a silent solution.
The first idea was to install roon rock on one of these nucs. This distro is designed for what it must do: run as a roon core.
Then I was thinking: Why not use a normal consumer linux distro, like linux mint, ubuntu, fedora. My normal pc is almost 10 years old does have linux why not replace it by a small silent one.
looking further for smaller linux distro’s that will speed up te boost, I found something spectacular: there are people stating that there are better sounding linux distros, then the recommended roon rock or nucleus.
Which distros to think about?
- audiolinux AudioLinux - The audiophile realtime plug & play operative system
according to the website: What about the sound? Clean, transparent, the last veil is removed... and a quick and complete support that no one is giving in Linux. Your system will be fine-tuned for the absolute best performance.
- Euphony 403 Forbidden
- maybe there are more solutions
For me installing these cost alot of time to install and moreover the licence are not free for only a try
Are there people who compared the sound quality between different linux distros?
