MPW
Looking for some help on an issue I experienced this weekend while replacing my Mediacom all-in-one modem/switch/wifi router/telephone to a dedicated modem (Arris SB8200), switch (Luxul AGS-1008M), and wifi router (Netgear AC1900 Nighthawk). I do not need the telephone functionality so that is not in the new setup.
When connecting the system in the follow in way, Roon was not able to find the core (Intel NUC): cable ethernet > Arris SB8200 modem > RJ45 > Luxul AGS-1008M switch > Netgear AC1900 Nighthawk wifi router (Intel NUC connected to Luxul switch via RJ45).
In order to get the Roon core to show up I needed the following setup: cable ethernet > Arris SB8200 modem > RJ45 > Netgear AC1900 Nighthawk wifi router (Intel NUC connected to Netgear wifi router's switch and Luxul switch is completely out of the setup).
I want to be able to run the Netgear wifi router into another room for better coverage, but can't because I need to use its switch to connect to the Intel NUC (and the other connections in my home). My understanding is that Roon is a bit fickle in this area, so I am looking for any advice to solve the issue and get the Luxul switch back in the mix. Thanks!
