hoping to tap into the group's collective knowledge here on a basic question...
given two amps with the exact same power specs but each with a much with different max gain -- assume the amps are identical in every other way and both are put in the same system driving the same speakers as follows:
amp #1: 30 db max gain | 8 wpc into 8 ohms
amp #2: 15 db max gain | 8 wpc into 8 ohms
what would be the effective difference between these two amps?
could it be as simple as: the source volume being set at the same level, one plays louder that the other?
thanks!!!
thanks!!!
