PS Audio P10
Cincy2
Tampa FL
I got an incredible deal on a PS Audio P10 power "regenerator". Couldn't turn it down. I'm currently using two Shunyata Tritons. One on each of my dedicated 20A lines. I owned one of these many years ago (the P300). It did a good job. I'm interested to see how things have progress at PS Audio and do a shootout between my Triton and this 65lb beast.
Anyone else have experience with one of these regenerators?
Cincy
Be careful, each unit has only a MAX. of 16.6 amps peek. If I were you I would use the P10 for your front end and a power isolator for your amps. You don't want to short change your amps for power when they need it during peek times. I use a BPT power isolator for my pair of mono blocks. The isolator has a MAX. of 65 amps peek. I even use another one for my front end as well.
Be careful, each unit has only a MAX. of 12.5 amps peek. If I were you I would use the P10 for your front end and a power isolator for your amps. You don't want to short change your amps for power when they need it during peek times. I use a BPT power isolator for my pair of mono blocks. The isolator has a MAX. of 65 amps peek. I even use another one for my front end as well.
It's true that George does this. All houses in the vicinity of a 60 mile radius complain of their lights dimming when he's listening ;)
Tried a P10, and wanted to give it a good go against my Triton but couldn't get past the reliability issues I had with it. Kept shutting down on power-up, and not sure I like the idea of effectively having a class D amplifier in front of my class A amps. A few people I know have moved on from their P10s as well...
