PS Audio LANRover
Audioshark
Staff member
Sarasota, FL
One reason why the Lumin sounds so good! It uses Ethernet.
From Paul McGowan
The LANRover
I have been hinting about a special device that improves the sound of USB audio for some time. Now it’s time to let the cat out of the bag.
When you connect your computer to your DAC through USB there’s a lot of problems getting the sound right. This is because your computer is a hostile environment for delivering clean audio data. Think of your computer like a noisy crowd and the music like a lone musician trying to be heard at a cocktail party. It’s near impossible unless you separate him from the crowd.
One trick you can use is to connect the computer through a USB hub, using two USB cables–one between the computer and the hub, the other between the hub and the DAC. While it may seem counter intuitive to improve something by adding another element in the data path, it works. In fact, the idea of a purpose built USB hub is what the famous Uptone Regen essentially does – and it works well – improving audio in every case. A USB hub, like the Regen, offers a degree of isolation between the computer and the DAC, though it’s not complete. Think of this degree of isolation as a doorway separating the noisy crowd (our computer). Our beleaguered musician is close to the open door and we hear him more clearly than before.
If we wish to remove even more of our imagined crowd noise, we can filter it by adding something like the AudioQuest Jitterbug for even clearer sound.
But if we want to eliminate the crowd noise altogether we need a completely new approach. Enter the LANRover.
The PS Audio LANRover leverages network protocols to fully isolate the computer’s crowd noise from the music. The LANRover employs two boxes: one connects to your computer, the other to your DAC. Between the two boxes a computer cable, commonly known as a CAT5, is used. The miracle of this technique is the near 100% isolation between the noisy computer and the quiet needs of a DAC.
By converting the USB data into packetized network data we get two major benefits. First, near perfect isolation cutting the computer’s crowd noise and jitter levels so effectively the level would be acceptable in a quiet library. And that has HUGE sonic benefits. Second, once converted to network audio, as opposed to directly connected USB audio, we can place a great deal of distance between the two boxes if we want to–the computer can be anywhere in the house and connect to your DAC anywhere else. We can do this even over WIFI. Imagine your computer’s no longer in the listening room, but upstairs in the office where it belongs. Bingo!
I’ll write much more about this revolutionary new product in the coming weeks. For now, here’s a video presentation I made to the Colorado Audio Society a week or two ago.
https://youtu.be/nQjJke5uM2g
...and I would add that Ethernet brings IP error correction.
Ethernet connection is one of the reasons why using a Meridian 8x8 endpoint with Sooloos never leaves me wanting to spend "crazy" dollars to get great sound.
Mike.......This sounds very interesting to me. I would love to move my laptop out of the sound room. I am curious what the retail price will be.
No need to get two boxes. You can get the upcoming sonore u-rednu to do the same (Ethernet to USB conversion) - and it is just one box.
The Rendu product linked to above outputs SPDIF, while the just released microRendu suggested by Elberoth outputs via USB.
Thank you for the correction Bill.
I may sound a bit I bitterered in the following statement it's not meant to be.
For nearly three years I have owned a ps audio DAC stating worth the pwdmkii model.
It never sounded as good as it looked to me. In fact the pwdmkii sat on a shelf for me. That is until my first offramp 5 and then my ap1/pp. these little costly devices opened up my brain to hiw good it could be. This led me to a msb DAC that did not need anything to add to it to sound stunning. I have lost Count of posts done on there forums to shout my results. Although some actually said yea it's better . For the most part the cult that is Psaudio and the cronies would never acknowledge anything. In fact as my threads got moved around Ps audio designers and others laid claims it was not needed. What a joke , finally the new DS DAC came out and it actually did sound like a good DAC . And the offramp and ap1 /pp made it sound worse lol. This led me to all,put assault on servers. The REGEn and the Corning did make it sound better on most any CPU . The new bridge sounds on par with server USB a big plus finally arrived. So now almost 3 years later wake up people look what we found .
I sold my DS not because it did not sound good it did but what it lacked was real dsd and weight behind the music . I like ps audio but dislike the enability to acknowledge improvements in there products from outside sources. This new device sounds like a winner but once again hype to hyperextended realism is the big question.
