Problems volume regulation iPhone 12
Qimic
Denmark
Hi. Does anyone else have problems regulate the volume after the app update. Mine is places at the very top of the screen mixed with other icons - is it possible to post a pic?
A New problem has appeared. The bar telling you if you are in tidal, your folder or others now appears with black vertical lines. I’m using dark theme
What is the iOS version you have on the iPhone 12?
Please try different themes and tell me whether the same problem appears.
If you have another iOS device such as iPad, please try it too.
Hi Peter
my Iphone 12 i running IOS 14.7.1 and it only seems to be a problem on Dark and light theme, Black and white has no problem. There is no problems on my ipad
kind regards Michael
Here is a picture of the problem
