Pro Audio Bono Lignofol AVF
Jerome W
Near Paris, France
Hello folks,
Wladek from PAB sent me 8 Lignofol Anti Vibration Feet to try. Lignofol is an extremely dense plywood.
I put them under my CCQs monoblocks. 3 per unit.
According to Wladek, Lignofol is the best material he heard from all the ones he made for his antivibration feet.
Results :
The effect on them is easily heard. The resolution increased. For all the spectrum, the sound is cleaner and more focused. To my ears the improvements are stunning. I am sure that I could notice blindly if they are used or not. I should try that with a friend. An easy test is to put the hand on the amps with and without the feet. Even at low volume, you can feel some vibes without the feet. Strictly nothing with the feet. Of course I'm keeping them. And I will surely order one more to use under the Giscours preamp. And I have to try one or two under my A23 SUT.....
Damn, PAB is addictive....!
Envoyé de mon iPhone à l'aide de Tapatalk
Well, I am trying now one foot under my A23 Hommage SUT and...it's better too. The effects are less obvious than under the amps but clearly noticeable on the voices and the bass. The timbre changed. The voices being a bit lower in frequency ( appearing more natural ) and more detached from the music. The bass is also a bit deeper and cleaner. This will never end ! :D
I have to tell Keith Aschenbrenner to try one under his SUT !
