Power distribution plan
plonkywonki
Viva la ..
I have now both hifi and non hifi at the same outlet.
Somehow I'm of opinion it might be better to get a power strip that that has clean outlets + also regular outlets so that I can connect hifi to the clean outlets.
Like some others on this forum say.. garbage in = garbage out.
Some simple option for me is good enough, maybe just a power strip with noise cleaning like the below example:
Premium-Protect-Line 60.000 A 8-way 3 m H05VV-F 3G1,5 | brennenstuhl(R)
Any thoughts to get this started up?
i would put the non hifi to a separate outlet.
then for the hifi take an outlet without switches. the one from your link is poison.
with all thouse filters the outcome would not be predictable
is line filtering for the hifi desired or not?
Another (but bulky) option would be a Dynavox X7000B or similar. that has both filtered and direct outs, to the direct I could add a cheap power strip to connect all the non hifi.
I find the Gigawatt power strip to very nice. It seems to be very well made, and very good sound quality.
They have a couple of models - I have PF-2 and was better sounding than Isoteck I had previously.
They do 3 models. I assume it comes Schko, US and Aussie outlets, possibly other too. I’ve had it for a couple of years and no issues. Highly recommend.
Power Strips – GigaWatt
