Playlist fails to advance after Firmware 13 installation
terryakhan
Toronto Canada
Playlist playback gets stuck at the beginning of the next track. To get out of this I will then tap on different tracks until I find a track that responds, after that playback is fine again, this occurs randomly.
Not sure if the new Firmware 13 has something to do with this, however, I think this started happening after the installation of Firmware 13.
When this situation occurred I always verify that my WiFi is active.
My U1 is ethernet connected from my Gateway.
Any advice please and thank you in advance.
If your music is on MinimServer, please reserve an IP address for it in the router.
If your music is on USB drive connected to Lumin, please reserve an IP address for Lumin in the router.
Make sure Lumin custom re-sampling is off.
Then power cycle both.
Clear the playlists and re-add them.
Hello Peter,
Thank you.
Mine is only Tidal, Lumin custom re-sampling is off.
I have cleared all my playlist and start new and also power cycle my U1, SoTM switch and routher/gateway.
Installed the new 13.0a firmware.
Will keep monitoring.
If you're on Tidal, please logout from Tidal from all devices and Lumin app, then re-login.
