PC's current system...
Puma Cat
East Bay, CA
Current system pics. Packed up the TT as I'm getting ready to move, which allowed me to simplify the system in a nice way.
Now it's just the Lumin P1 and Constellation Inspiration integrated & the amazing Altaira stack driving the Harbeths...
Simple. Simple is good. VERY good...
You must be pretty tired of packing by now!!
I'm approx. 75-80% packed at this point, so it's well under control.
On a side note, I trained assiduously for 10 years as a classical ballet dancer (as in class 4-6 days/week), and then after that took up motorcycle roadracing, and then mountain biking to be fit for motorcycle road racing, so I'm used to hard work. I like it, actually.
Pounding around Miller on my CBR600RR on a track day back in the day...
Discipline is a good thing...
Are you using the preamp section of the P1?
Yes. It's my preamp. I set the Constellation Inspiration to unity gain and adjust volume using the P1's LEEDH digital volume control, which is really superb.
Before I broke down the TT and packed up the EAR 324, I also used it as my pre when listening to LPs. It's also my preamp when I use my CJ LP70S power amp and my Amp Camp Amp bridged monos.
And, and it was superb for those applications and components. It's one of a handful of the best pres I've ever heard.
As I've decided not to move to Washington state after all, I reset up my Michell Gyro SE TT with SME V arm and some 'lil ole Koetsu Urushi cartridge so I can spin LPs once again, so I thought I'd update the system pics with the currently configured system. Shown here also with my segmented Altaira system (and we all know what Altaira does for a system :woot:)
So...once again, the overall set-up: Harbeth 30.2 40th Anniversary speakers on Resonant Woods stands in figured maple. Shunyata Alpha V2 speaker cables.
Close-up of the main rack:
The Lumin P1 streamer/DAC/preamp (top lieft) and Constellation Inspiration integrated (bottom left) are on the left side and my Michell TT with SME V arm, Koetsu Urushi Vermilion cartridge, and EAR324 phono stage on the right side of the rack. Acoustical panels by GIK Acoustics.
The Lumin P1 and Inspiration integrated amp are fully dual-mono internally. On top are Shunyata Altaira SG ground-plane noise reduction hubs on top of each component, one dedicated to the Lumin and one dedicated to the Inspiration integrated. These specifically reduce ground-plane noise and are transformative in the improvement they provide for the system overall.
The P1 uses the LEEDH* lossless digital volume processing technology, which easily is the best volume control "technology" I have EVER heard, so I simply set the Inspiraton to Unity Gain, and adjust the output volume with the P1's LEEDH volume control/technology. D/A conversion is handled by Dual ES9028PRO SABRE DACs in Mono mode and a Femto Clock System with precision FPGA distribution.The P1 also uses dual-toroidal mono Plitron transformers housed in an "internal chassis" that is fully shielded from the rest of the circuitry, and also uses fully dual-mono Lundahl transformers for the DAC section. Moreover, the P1 has an SFP cage so I can simply run Corning single-mode 9/125 LC/LC fiber directly into it from the remote server room. No hassling with Ethernet and USB cables anymore.
The solid-state Constellation Inspiration integrated puts out a conservative 100 Wpc. The "preamp section" of the Inspiration integrated amp is literally the standalone Inspiration preamplifier combined with "half" of the output section of the 200 Wpc Inspiration power amplifier into a single chassis. Both the "preamp section" and the "amplifier section" are a fully dual-mono architecture.
The nice thing about this system is that it's considerably simpler than my previous system, and it just...works. A single pair of ICs connects the P1 to the integrated and I now only need 3 power cords instead of...7!
Simpler really is better, as Linn used to say back in the day, and I have to say this system sounds...FANTASTIC. :cool:
Oh, I should also mention the P1 is a fully-functional AVR for Home Theatre applications, as well.
*-LEEDH was developed in Switzerland, and is used by very high-end audio companies e.g. Soulution, Wattson Audio, Vermeer, and Metronome, etc. You can read about it here:Presentation | Leedh Processing
