bluegrassphile
Is it correct to say as ohms decrease amp power output increases (due to less resistance)? For example, if you have an amp that outputs 100 wpc x 2 at 8 ohms, it will effectively be outputting more with a 6 ohm speaker. Another example...let's say you have a Luxman 509x that outputs 125 wpc x 2 at 8 ohms. Will it output more wpc with Harbeth 6 ohm speakers? IOW, is there a power advantage to having 6 ohm speakers? As you can see, I'm a total novice on this subject. But, is the above information accurate?
