brad225
I have a Marantz 7703 in our living room for HT and music.
I have been using it with Roon for a couple of years with no issue.
A week ago Roon stopped seeing it and at first I assumed it was something in the latest upgrade.
As it turns out the Marantz has lost its ability to make a network connection via either hard wire or WIFI. I have used the network setup process and a total revert to factory specs and nothing changes. I have called Marantz and all you can do is leave a phn # and so far received no response.
I have come to the decision that the network circuit has died.
What I am looking for is some device to connect to the Marantz that will be seen by Roon. The music from the Marantz is only background sound so the quality is not really important.
Any suggestions for a product that will fill this need?
Thanks Brad
Thanks Brad
