Neutrik PowerCon Power Cords
Dizzie
Sacramento
Any recommendations for good but not extravagantly expensive power cords with Neutrik PowerCon terminations?
I only know of one company, Audience.
Thanks,
Don
Triode Wire Labs. You can ask Peter to use powercon connectors.
Shunyata is widely known for their power cords. They have several product lines that deliver value across multiple price points.
Shunyata and most cable companies can terminate their cables with just about any required termination.
I am not seeing any manufacturers (except Audience) offering the powerCON termination option on their websites. I am having a hard time picturing large diameter power cords like Shunyata's Alpha and above shrunk down to powerCON connector size. I think many cable designs are not viable options for powerCON.
This is exploratory at this point. I am considering a device that requires a Neutrik powerCON power cord. Purchasing it may not happen but I have to consider power cord requirements in my final decision. Major bummer because I have a surplus of excellent "normal" power cords.:(
After looking at the Neutrik website, I see that they make several different PowerCon connectors which can accept different size cable diameters.
As previously suggested it would be advantages to contact the cable manufacturers direct.
Also, you will need to reference the particular piece of equipment so that they can assure proper compatibility.
I am not seeing the different cable diameter options.
