Marantz CD17 KI series Plinius pre & mono amps, Paradigm Studio 80 speakers with WWorld interconnects & Kimber speaker cables, loved it & it was very musical, but I ;love all my children equally...
Haha! I know what you mean.
It has been a while since I last wrote so what follows is a short update.
In the next couple of months my audio system will be moved from our holiday home in New Zealand to our tropical home in Singapore. Audio rooms in both houses are similar in size but vary in construct and amount of passive acoustic controls used. This presents an interesting opportunity to observe and compare the impact a room can have on the quality of audio reproduction.
While the Musical Fidelity NuVista 800 amplifier continues to impress with its outright musicality, its performance is taken a notch higher when the power cord is connected to the Ansuz Mainz D8 distributor. Just about every facet of the audio reproduction is improved by the D8 ā but most significant for me is the progress with layering, depth and overall scale of soundstage.
Hey George & Le Roy,
Absolutely agree, the Ansuz Mainz D8 is good stuff. Even my Nordost Qbase QB8 fully loaded with Ansuz Sparkz harmonizers can't match it. I can now understand why Lars thinks this product is one of their finest achievements. Did either of you buy additional Darkz footers to sit under the D8?
Hi Ralph
No I didn't get the footers yet. Again when Lars was here to show the DTC power cord he also added a diamond digital cable and the DTC footers under the Aavik. Too much to fast to really let the sound sink in and how much each piece contributed. With all in place I couldn't believe what I heard in my home with my system. I hope to soon demo each of those pieces along with the Dx.1's and see in what order I want to upgrade.
Ralph, I've tried using the Darkz footers under the MainzD8. But with the weight of the power cords, it is a balancing act for the footers to make contact with the rack.
Ralph,
Thanks for the updates..
What's your opinion on the sonic improvement you've heard on D2.1 ?
Hey Tom,
Without having the D-2 and the D-2.1 side by side in the same audio system it is not possible for me to comment on the sonic improvement of the .1 upgrade.
This means sending my speakers back to the manufacturer for the upgrade will largely be an exercise in āqualifiedā faith.
The upgrade itself is considerable;
New motor system
New rubber suspension
New airflow system
New binding posts
New airflow back panel
Cross over and other smaller changes
When it comes to loudspeaker design I have the utmost respect for Michael BĆørresen, Raidhoās chief designer. Michaelās research in loudspeaker mechanics and resonances coupled with their most recent findings in airflow design place them in a very rare league. In particular Raidhos application of and advances in computer aided velocity measurements not only reduce or eliminate the need for damping materials and tombstone like cabinets but progress the positive audible characteristics for which Raidho is already well known.
So, while I havenāt had the chance to compare a D-2 and D-2.1 side by side I will take Raidhoās word on the benefits of the upgrade and thank them for the opportunity of having their most up to date loudspeaker.
I will happily and separately reply on your other questions tomorrow.
Hey Tom,
New motor system
New airflow system
New binding posts
Fair comment Le Roy. Some of my audio friends have located their Ansuz Mainz D8 on a mid rather than lowest rack shelf as the careful combination of power cables heading up and down seems to help the balancing act you speak of.
Hi Ralph, it is my understanding the there is not just a new motor system in the new X.1 series but whole new drivers.
These drivers are purported to play at much higher SPL's. My question is if you change the driver are you changing some characteristic of the Raidho sound that makes them so endearing to the people (including myself) that are spellbound by their magic?
Ralph,
[ā¦]
How long have you had the Mainz D8 ? I'm using mine on the front end and the Nordost Qb8 for my mono Amps....Very happy with the results.
Possible sonic benefits of Darkz footers over Nordost TC ?....Or stability improvement, or both ? [ā¦]
Hello All = I am moving from a system comprised of Shindo D'Yquem amps/Vosnee-Romanee pre/Devore O96 speakers to a Viola Lab Symphony amp/Crescendo pre and Raidho 2.1's. While the Shindo/Devore setup conveyed lovely tonality and emotion and was extremely captivating, ultimately I found it to be a two-dimensional, smaller soundstage than I am desiring. My hope is that the Viola/Raidho pairing will bring the same beautiful tonality with more layering, depth, larger soundstage. Any thoughts or advice are greatly appreciated!
