Mister Pig
- Feb 11, 2014
I am strongly considering trying a tri-amped system configuration sometime this year. Since the speakers I am using ar open baffles, it is very easy to bypass the passive crossover and get this whole thing wired up.
At first I thought of using something along the line of a Mini DSP since I could get an electronic crossover, digital time correction, and measurement capabilities. But I have been doing some reading where certain owners feel the digital converters in this component are sub par.
Now I am a SET kind of pig, and that means having an unaltered source signal is of the utmost importance, even through the amplification stage. The idea of converting a source signal to digital and then back to analog does not feel right to me. Even though I understand how valuable being able to manipulate the signal in the digital realm can theoretically be.
My other option is to use an analog electronic crossover. Now since the speakers I have use a coax driver supported by two woofers per side, it seems that digital time correction for driver time alignment is of minimal benefit. Traditional room treatments can be used to take care of early reflection points. So perhaps an analog electronic crossover would be a choice that better fits my philosophy.
The only problem is that there are very few electronic crossovers intended for home audio use. The Marchand is perhaps the most recognizable choice, but the plug in modules are somewhat inconvenient, and make the tuning process somewhat difficult.
The other option is pro sound companies, where most of these devices are used anyways. Something from perhaps RANE, DBX, Ashley, or Sampson might be reasonable choices. The only problem is that most use balanced type inputs, and my gear is single ended RCA output and input jacks. As I understand it there are adapters, but once again I hate using all that extra metal and compounded connections to get the job done.
So has anyone else gone down this road? What have been your experiences?
Regards
Mister Pig
Regards
Mister Pig
