While I dont know the absolute stability of this amp for bass duties, I can imagine 2 of these amps with an Emerald Physics CS2.3 system (used for about $3.5K, new $6.5K) would make a killer system costing in total between $6K and $10K. You need room for these though as they have 2x 15" open baffle woofers.
I dont see any problem driving the M/HF drivers with the JOB, but the second amp would be driving 4 woofers. However, since they use electronic X-over, the power loss will be minimal, plus the whole thing is like 95dB efficient, so it should work for the bass too.
Having heard the old 2.3 and 2.7 EP systems, I can attest that they cannot be beat for dynamics and due to the controlled directivity, electronic X-over and DSP/DRC control of the drivers and room interaction, I expect thay could take down systems costing 3x as much.
Since you have ever heard the EP speakers, then you KNOW what I mean.
What do you think??
What do you think??
