Hello and welcome. Looks like the 500 is a beast. I found this:
McIntosh MC500 980,000yen(April, 1994 release)
Description
Stereo power amplifier which compiled years of technical store recording and the know-how into one book.
The signal system consists of a whole page balance stream composition and a 10 parallel push pull output, and has realized the low-distortion output.
Moreover, irrespective of a load impedance, the output transformer enables the fixed high power supplying, and is equivalent also to the low-impedance speaker with the output current which reaches Peek 115A.
The temperature rise is reduced by a total of eight large dimension heat sinks or an original efficient amplifying circuit, and the air cooling without blower is realized.
Furthermore, seven protection networks, such as a temperature protection with which an emergency over-temp was equipped, a sentry monitor, a turn-on delay, a power guarding system that prevents clipping distortion, were carried, and it has taken all possible measures.
The power guarding serves as a patent circuitry which makes possible an over drive of a maximum of 14dB until it controls input voltage automatically and distortion reaches to 2%, comparing the wave of an input/output. This has prevented the destructive of the speaker by clipping distortion.
Moreover, the effluve of DC electric current which occurs in the outage of an output transistor etc. by an output transformer is prevented.
The power meter which displays true output power correctly by the product of a voltage and an electric current is carried.
This meter has one about 10 times the speed of response of this compared with VU meter for pros, and if a pointer reaches a peek in WATTS mode, after only the time recognized by people's eye will stand it still, it descends. Moreover, in HOLD mode, it is fixed at the upper of peek power, and if there is no output beyond it, it will descend slowly the velocity for 6dB/.
The circuit board serves as module construction which uses a gilding connector.
The gilding output terminal of a banana-plug correspondence is adopted as a speaker terminal, and an interconnection of the cable of 5mm of core thickness of a lines is also possible.
The bridge operation functionality which can be used also as monophonic amplifier of Output 1000W is carried.
The digital logic remote power control terminal which can be operated from the control center of a mac is carried.
When two or more generation is connected, the delay circuit for 1/tens of second works, and a convergence of a rush current is prevented.
Rear
Rating of a mode
Form Stereo power amplifier
Output power (sinusoidal consecutive output) stereo: 500W+500W (2ohm, 4ohm, 8ohm)
mono: 1,000W (4ohm, 8ohm, 16ohm)
Load impedance stereo: 2 ohms, 4ohm, 8ohm
mono: 4 ohms, 8ohm, 16ohm
Output frequency band 20Hz - 20kHz
THD (20Hz - 20kHz) 0.005% or less (250mW - Output power)
Cross modulation distortion (SMPTE) 0.005% (when peek power does not exceed the twice of an Output power at the moment)
Frequency band 20Hz-20kHz+0 -0.25 dB
10Hz-100kHz+0 -3.0 dB
SN ratio (A network) 85dB
115dB (at the time of an Output power)
IHF dynamic head room 2.1dB
Dumping factor 200 (4-ohm output)
Input sensitivity/impedance 2.2V/10kohm
Power guarding Prevention from clipping. It is less than THD2% to over-drive 14dB in1kHz.
Power source AC100V, 50Hz/60 Hz, 14.4A (Underwriters Laboratories/CSA)
Dimensions Width 445x height 255x depth of 491mm
On a more ffordabe end the Parasound P6 or P7 might be a preamp to look at. Or, maybe look for a used Mac that has the features you need and match the amp.
Looks like theMC500 was sold from 1994 to 1999 atabout $7k originally
The Mclntosh MC500 is a 500 watt per channel stereo power amplifier created in a stunning new contemporary industrial design. Two 5½ inch True Power Output meters are mounted behind the ½ inch thick glass front panel. The high efficiency of the MC500 circuits together with oversize heatsinks utilizing convection cooling eliminates the need for internal cooling fans. Typical Mclntosh attention to detail includes the use of 1% metal film resistors and polypropylene capacitors throughout. Internal heatsink module connectors use gold plated contacts to ensure reliable operation. Gold plated Balanced as well as Unbalanced Input connectors ensure reliable signal transfer.
