Luxman M10x arrives at Suncoast Audio
Audioshark
Staff member
Sarasota, FL
What an amp!
WOW!
For sure. I snuck into the store yesterday to listen. What a great amp.
I see that Luxman power amps have an input selector on front panel. Nice.
Is it ok if balanced inputs are connected to streamer/DAC with volume control and unbalanced inputs to AVR for HT usage - at the same time, using the input selector on amp to choose the active input?
For some (probably most) amps it is not permited to use/connect both balanced and unbalanced inputs at the same time even if they have an input selector - e.g. Moon 860A v2. It is very clearly written in the Moon's manual. I haven't found anything similar for Luxman.
Anyone?
That's the good part. Input selector is not on the back - it's on the front panel.
