Lumin X1 Antipodes Issue
further
Antipodes Audio recently pushed through software updates . One of the major parts was an update for Roon server to meet changes Roon was to implement for Linux on November 3. I now am having issue with Lumin App telling me my K50 server is offline, but it is not. I have restarted Roon, rebooted the K50, deleted Lumin App from my iPad and reinstalled, but still not finding the server on the App. This is happening both on my iPad and my M1 iMac.
When I did the extensive updates with Antipodes, Roon web application could not find my Core (old software version), and I had to deauthorize that Core. Roon then found "new" Core and my music on the hard drive. I have been able to use Roon web app to play through my DAC's, including X1. I suspect similar issue may be happening with the Lumin App.
Should I "Remove Music Library" from Options under Music Library?
Firmware on Lumin is 14.2 and App version is 7.0.9.
I had Roon selected as server in the K50 and changed to MinimServer. Lumin App on my Desktop M1 then detects MinimServer (antipodes) in Music Library and can play via the Lumin App. K50 no longer shows as Music Library option. If I activate Roon as the Server only, MinimServer shows as Offline. I do find I can activate both MinimServer and Roon Server in Antipodes Server Dashboard and Lumin shows MinimServer (antipodes) as accessible. This is different than before Antipodes software push changes, but it works. If I leave Roon Ready On in the App, I can switch to playing Roon from the Roon web app or select and play from Lumin App. If I shutoff Roon Ready in the Lumin App, my X1 does not show as an Audio Zone in Roon.
Thanks Peter, I saw your post after I did mine. I was under impression that Antipodes server choices were confined to one choice, but obviously not in this case--I highlighted both now in the Antipodes server dashboard.
