Protyreus
Hi all,
I use the Lumin U1 mini to feed two separate systems either through Tidal or the Naim Unity Core.
A) McI C53 / Anthem STR PA / Nubert Pyramide 717
B) McI C8 / McI Mc275 MKVI / Wharfdale Linton Heritage
Via Coax feed there is audible sporadic crackling noise similar to an old Vinyl record.
Audible on both systems, cable exchange to no resolution
Via USB everything is fine - would any of you have a guess what the root cause of these cracks on the Coax port could be ?
Also everytime I select a new song in the playlist there is a split second cut off of the track. Is this normal for the U1 Mini ?
I find this rather bothersome for a streamer in this price range.
Thanks a lot
Thanks a lot
