Firmware 2.03 (2020-7-8)
- Fix UPnP CallStranger vulnerability CVE-2020-12695
Firmware 2.02 (2020-4-2)
- Add disk full LED status (Blue on, Red blink) for single partition scenario
Firmware 2.01 (2020-4-1)
- Fix a problem with L1 formatted by Mac OS. Those L1 upgrading to this firmware will automatically invoke a complete rescan.
Only when you experience abnormal issues with the L1:
PROCEDURE TO RESET LUMIN L1
The following procedure tells the L1 to recreate its database from existing music in its HDD. Although this is not a format procedure and is not expected to cause data loss, having backup of your music is preferred.
1. Firstly, please connect the L1 to the computer via USB, and empty Trash or Recycle Bin. Then safely remove the L1, then disconnect the USB.
2. Make sure USB is disconnected, and standby the L1
3. Unplug the power from L1
4. Connect the network cable to L1 (if it is not already connected)
5. Press and hold the L1 power button
6. While still holding the L1 power button, plug in the power cord
7. Keep holding the L1 power button for about 30-40 seconds - during which observe the various LEDs blink. Keeping holding it until L1 finally stops blinking, or goes into Standby mode with red LED on.
8. If the red LED is on, press the L1 power button once to bring it online
9. After the L1 is online, please give it time to recreate the database (green LED blinking even if not accessed by other streamers).
10. Lumin app -> Settings -> Options under L1 -> Reload Music Library (If you have previously renamed the L1, the name is now reset to default)
11. If the Reload in the previous step does not occur normally, please double tap iPad home button, swipe away the Lumin app and retry the Reload Music Library.
