Ozarktom, it seems you prefer the Sony to Lumin? Btw, what's your system?
Sorry, I have never heard the Lumin. But for $2K this Sony is a steal. Incrdible soundstage and very organic sound. It rivals all the Dacs that I have ever owned. Dan Modright and Vinnie of Red Wine Audio is now modding the Z1 with tube regulation if you want the sound of tubes with your DSD. The Modright full mod is $2995, $2495 until the end of April. Both Dan and Vinnie believe they have a new reference on hand with the Z1. But the stock unit really shines by itself.
My present system is the Job 225 amp and the Zellaton Emotion speakers.
Sony has also another less expensive Hi-Rez music player; the Hap-S1 for $1,000 - just goggle it to see all what it does and supports and features.
I checked the sprcs and I doubt if that one is the same. The S1 only stands 3.5 inches tall, comes with 40 watt amp and a built_in fan, and weighs 12 pounds. Z1 stands 5 1/8 inch high and weighs 31 pounds. There is probably no room to mod the S1 with any tube stages.
And Steve Stone wrote this in his Absolute Sound review.
"Throughout the review period as I put the HAP-Z1ES through its paces, I looked for reasons the player might be not be considered a true high-performance component and found none. If you plan to spend more than $2000 on any digital front end, whether it be an audio-computer, CD player, DAC, network player, or any other front end that uses digital files as a source, and you don’t audition a HAP-Z1ES, you are failing to consider what may well be the benchmark digital product of 2014."
NAD, does it have a high-res music server too? ...Or two?
Very curious about this product. i sent them an email but got no response....:-(
Curious about which product? The Lumin? Let me save you the time - it is exceptionally good. I own two!![]()
