haygeebaby
- Jun 9, 2018
Happy new year guys.
I've had my LS28 since early 2017. Purchased brand new.
Wonderful unit - sounds great.
However at around 947 hours the stock right side tubes started to crackle. I swapped the tubes out with new items. The left side was fine.
Now running the new tubes - at around 850 hours I notice that the right side tubes start to make crackles again.
Again - left side was fine.
I changed the tubes out again and this time decided to try EH units. Just recently the right side started to crackle again. Around 400 hours into the new tubes.
The unit sounds lovely when new tubes are installed.
The unit is also housed in a hifi rack and is on still points.
The rack is well ventilated.
Above the LS28 is a PH9 - and that unit has been problem free as was purchased at the same time. The tubes in the PH9 give no problems.
Has anyone experienced similar issues with ARC gear?
Any thoughts on what is wrong with my unit that is causing these issues?
