:heart:
The Fusion Monoblock Vacuum Tube Power Amplifier comes complete with power, punch, and delicacy. The 211 tube was selected as the main power output because of its long life and value price as an industrial heating tube (10,000 hours and $60). The Fusion provides so much weight in the bottom end that a powered subwoofer is irrelevant. The highs are extended with no loss of the delicate harmonics or air. In terms of power, the Fusion can handle speakers down to 80 dB sensitivity. For safety, the Fusion has a digital protection circuitry, which can handle surges from the outlet or internal short circuit should a tube fail. High quality construction and parts will contribute to years of pleasurable music.
Construction Details and Features:
Mono Amplifier: All steel chassis with aluminum face plate
Remote Control 12V trigger
Custom Wound Audio Transformers with a core of German grain oriented silicon steel. 15th generation proprietary design. Secondary can be configured for a 4 ohm or 8 ohm load.
Easy Biasing with top panel bias testing terminal with bias adjustment controls.
State of the Art Components: Gold plated RCA input jack and one XLR input.
Built in digital protection and soft start circuits.
Technical Specifications:
[TABLE="class: techs"]
[TR]
[TD]Rated Output Power: [/TD]
[TD]200 W per channel at 8 ohms, 25Hz to 40KHz[/TD]
[/TR]
[TR]
[TD]Frequency Response: [/TD]
[TD](at 1 watt into 8 ohms) 14Hz to 50KHz + 1dB[/TD]
[/TR]
[TR]
[TD]Distortion THD: [/TD]
[TD]Less than 1% at 150 W output, 21Hz to 28KHz[/TD]
[/TR]
[TR]
[TD]Circuit Type: [/TD]
[TD]Ultra Linear, Class AB[/TD]
[/TR]
[TR]
[TD]Input Impedance: [/TD]
[TD]100Kohms[/TD]
[/TR]
[TR]
[TD]Input Sensitivity: [/TD]
[TD]2.35mV at 1KHz and 8 ohms for 200 watt output[/TD]
[/TR]
[TR]
[TD]Output Impedance: [/TD]
[TD]4 ohms and 8 ohms[/TD]
[/TR]
[TR]
[TD]Tube Complement: [/TD]
[TD]2 pcs. 211 power output; 2 pcs. El34 power drivers, 2 pcs. 12AT7 power drivers.[/TD]
[/TR]
[TR]
[TD]Warranty: [/TD]
[TD]Two year limited parts and labor. One year or 1000 hours whichever comes first on Jolida Tubes.[/TD]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]100Kohms[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]Warranty: [/TD]
[/TR]
[/TABLE]
