Is a 600 ohm preamp output impedance to high for 28BSST2's ? ...
joeinid
Super Moderator
NY
Hi James,
Any thoughts? Audio Research preamps are typically 600 ohms. My GAT is <100 ohms and works wonderfully but is single ended.
Thanks!
Input impedance is a bit low at 15k but it shouldn't have any issues. 600 ohm output from a tube pre is probably a cathode follower output so it should have plenty of current, no problem driving the Bryston.
What's the input impedance on the Bryston amps?
In the manual it is listed at
INPUT IMPEDANCE
15K
Ohms
balanced.input.(XLR)
[TD="bgcolor: rgb(0.000000%, 0.000000%, 0.000000%), colspan: 6"] [/TD]
[TD="bgcolor: rgb(0.000000%, 0.000000%, 0.000000%)"] [/TD]
But I think it might drop a little lower is reality.
15K each leg on the Balanced and 50K on the RCA single ended. You want at least a 10 to 1 ratio between preamp output impedance and amplifier input impedance,
james
