Inexpensive Tube Tester Recommendation
I don’t know of anything less expensive unless you can find used.
The 606 is so simple that not much can go wrong.
Perhaps a better option is to Pick up a TV-7 from FleaBay for around $500 and send it out to Dan Nelson (the TV-7 guru) for refurbishing ($200-$300 approx) and your all set.
The Orange is a basic "Go-No Go" tester. It really doesn't tell you much about the tube beyond that.
It's sensitivity and accuracy are only acceptable at best.
But it is new.
Good luck with your purchase.
