iFi audio
- Aug 30, 2018
iFi audio ZEN CAN Signature 6XX
As you may all know, iFi audio ZEN CAN Signature 6XX was originally to be Drop-branded. It's now iFi branded but will still launch as a Drop exclusive.
SEE IT ON DROP HERE!
iFi audio ZEN CAN Signature 6XX features a (bypassable) high fidelity active EQ synergistic with the amplification circuit itself to tailor the sound of the amp to the characteristics of the popular Sennheiser HD6XX (also suitable for the Drop HD58X and the regular HD580 / 600 / 650 / 800S) to bring out the best in them, plus a (bypassable) highly realistic analog spatializer for transforming your headphones into a spacious home HiFi listening environment.
iFi audio ZEN CAN Signature 6XX will feature sophisticated circuit design and high end components as also found on the Pro iCAN to produce class-leading results in the traditional measures of performance such as THD, noise floor, output power, etc.
Here's a bit of extra information we're putting here, ahead of even the Drop post. The correction curve applied by iFi audio ZEN CAN Signature 6XX will be as follows:
Specs
iFi audio ZEN DAC Signature
A Standout DAC Gets a Signature Upgrade
With a sleek form factor, solid build, and stellar sound, iFi audio’s ZEN DAC is one of the most talked-about USB DAC/amps on the market today. Now we're taking the conversation further in a Drop-exclusive model: the ZEN DAC Signature. Like the original ZEN DAC, this premium iteration can be powered by mains or a connected USB source. It boasts the same bit-perfect Hi-Res audio support, with PCM decoding to 384kHz, as well as native DSD and MQA decoding.
Where the Signature stands out is its upgraded circuitry with premium parts selection for unparalleled analog conversion. The Signature features high-end, low-noise capacitors and resistors found in iFi’s flagship Pro series to preserve the signal in the purest form. Any downstream amplifier will sound crystal-clear when paired with this game-changing amp, but the ZEN DAC Signature (with its balanced circuit and 4.4mm output) makes an exceptional duo with the purpose co-designed ZEN CAN Signature 6XX.
Specs:
Specs
- Inputs: RCA, 3.5 (single-ended), 4.4mm (balanced)
- Headphone output: 6.35 mm, 4.4 mm
- Gain: 0 dB, 6 dB,12 dB,18 dB adjust
- THD+N (A-Weighting): 0.0066% (balanced), 0.0058% (single-ended)
- Maximum output power (16 ohms): 3.0 V / 600 mW (balanced), 4.0 V / 1000 mW (single-ended)
- Maximum output power (300 ohms): 15.1 V / 756 mW (balanced), 7.6 V / 196 mW (single-ended)
- Maximum output power (600 ohms): 15.2 V / 385 mW (balanced), 7.6 V / 98 mW (single-ended)
- SNR: -112 dB (balanced), -112 dB (single-ended)
- Dynamic range: -112 dB (balanced), -112 dB (single-ended)
- Frequency response (-3dB): 10 Hz – 200 kHz
- Function Button: HD6XX adaption and/or XSpace; Bypass
- IMD: 0.0098%
- Crosstalk: -50 dB
- Zout (headphone out): 0.25 ohms (single-ended), 0.5 ohms (balanced)
- Zout (balanced line out): 200 ohms
- Maximum power consumption: 13 W / 2.6A
- Dimensions: 4.6 x 3.9 x 1.2 in (11.7 x 10 x 3 cm)
- Weight: 1.87 Ibs (0.85 kg)
Specs:
- Input: USB-B 3.0 socket (USB-B 2.0 compatible)
- Supported formats:
- 44.1 / 48 / 88.2 / 96 / 176.4 / 192 / 384 kHz, PCM
- 2.8 / 3.1 / 5.6 / 6.2 / 11.2 / 12.4 mHz, DSD
- 353 / 384 kHz, DXD
- DAC: Bit-perfect DSD and DXD by Burr Brown
- Power consumption: 5V / 174ma, P = 0.887W (on idle using included iPower)
- Audio RCA output (unbalanced): 2.1 V fixed, 1 V – 3.3 V maximum (variable)
- 4.4 mm Pentaconn output (balanced): 4.2 V fixed, 2 V – 6.2 V maximum (variable)
- Z output (unbalanced): ≤ 100 ohms
- Z output (balanced): ≤ 200 ohms
- SNR: < -117 dB(A) at 0 dBFS (unbalanced / balanced)
- DNR: > 117 dB(A) at -60 dBFS (unbalanced / balanced)
- THD+N: <0.0011% at 0 dBFS (unbalanced / balanced)
- Weight: 1.65 lbs (0.75 kg)
