The GAT should have no problem as it's output impedance is 100 ohms. That was more of an issue in the old days with a 10 ohm input resistance and 500-1000 ohms or more output resistance. Dave Wilson covered it many years ago in TAS. Biggest tip offs you have an issue is loss of dynamics and low end.
220 ohms going into 51K is just dandy.
Years ago, ran the small Goldmund amp that used the Job circuit quite successfully with the Cj ART S. 3 (with an output impedance of 500 ohms) without any issues.Thanks Myles. Yes the GAT is quoted as being under 100 ohms and sounds superb with the Job and every other amp I've tried so far. I was thinking of trying something like the McIntosh C50 on the Job because I want the tone controls for some situations.
Joe...the only thing you should be aware of is the output impedance of the preamp is usually measured at a particular frequency, usually 1KHz and usually the output impedance changes at different points on the frequency curve. So I would want to have a minimum of 10X spread between the highest point of the output impedance and the input impedance of the partnering amp. So for example, the stated output impedance on my ARC Ref 3 is 600ohms via XLR and 300 ohms via RCA connections. So the 10X rule would suggest an input impedance of 6Kohms (on XLR) / 3Kohms (on RCA) would be sufficient. However, the output impedance of the Ref 3 rises to as high as 1437ohms (balanced or via XKR) and 625 ohms (single-ended or via RCA) at 20 KHz. So via balanced connections, I would want an amp with at least a 15Kohm input impedance. Which is why ARC recommends an amp with a minimum of 20Kohm load for the Ref 3 (actually for most its preamps because presumably they all measure similarly in terms of output impedance). Having said all of this, in your specific case, sounds like there is more than plenty headroom and if you are not experiencing any tonal imbalances (i.e., the preamp-amp partnering) is delivering a tonally neutral presentation (no specific part of the frequency spectrum being highlighted or being sucked out) than sounds like you are fine.
Yes, Cyril is absolutely right, and the lowest the closest and more constant that output impedance is at 1 kHz, 5 kHz, 10 kHz, and 20 kHz, etc., the better it is.
Eg.;
- 30 milliohms at 1 kHz
- 45 milliohms at 5 kHz
- 55 milliohms at 10 kHz
- 75 milliohms at 20 kHz
=> From 1 kHz to 20 kHz the variation is from 30 to 75 milliohms - or 45 milliohms difference (very modest rise) in output impedance between those chosen frequencies, which is very good and means a deft use of feedback and an adroit balance between open- and closed-loop gain.
Output impedance unit is ohms not milli-ohms; for preamps like Joe's GAT it's 100 ohms and for the Rowland Consummate 150 or 300 ohms.
So based on this the match between my preamp & mono amps is very good Myles? Preamp 10 ohm, amps 50 kohm.Output impedance unit is ohms not milli-ohms; for preamps like Joe's GAT it's 100 ohms and for the Rowland Consummate 150 or 300 ohms.
Also, I couldn't find any pre with a 30 ohm output impedance?
Most manufacturers believe 10:1 ratio is a minimum with some believing 20 or 40:1 being even better. Some feel the higher the better.
