How much quality is on a master tape?
A friend of mine had a very nice R2R collection and we listened to quite a bit of music that way over his well setup system in the 90's. I'll say dynamic range, frequency response and tape hiss be damned, it still sounded so analog and so "right"
Tape is supposed to be the best sound quality. I’ve only experienced an older Sony reel to reel and it was pretty awesome. I’m sure a new setup properly done should be excellent.
It’s highly unlikely anyone has a dynamic recording they listen to which wouldn’t work with tape. Also, it’s unlikely someone can hear 20khz, so who cares if you can record above that.
I will happily put my tape up against any other format and beat it all day long. The proof is in the listening.
My father had a R2R. I’m not sure what his favorite was - Vinyl or R2R. Both beat digital - i.e. SACD, CD, and Streaming. I’m surprised that more so-called audiophiles don’t own a R2R - me, a mere music lover, included.
“I’m sure a new setup properly done should be excellent.” So, why don’t more audiophiles own a R2R? Have modern-day audiophiles just become lazy; convenience oriented instead of quality oriented?
If not for the convenience aspect of digital, I would only own some turntables and R2Rs. Sound is by its very nature analogue. You may twist, turn and torture digital all you desire - but it’s not analogue and never will be. And tape and vinyl is a lossless format so nothing (.... very little) is lost .... Rather in respect to compression, it retains the sound as close as it can be to what was originally recorded. Isn't this what a true audiophile desires?
Tape and Vinyl gives you better quality. Besides some modern-day female vocals, older music is what I listen too. Tape and Vinyl is especially good on recordings made in the 50s, 60s and 70, as they were recorded in analogue. It has a depth and authenticity that more modern mediums just can’t match - and never will. Analogue purity will always remain the King of sound for such type music.
I think Mike told me R2R tapes can cost upwards of $500-600 dollars each. Not for the faint of heart.
R2R is okay for background music, but absolutely sucks when you want to listen to songs 3, 7, and 10 (or whatever combination). I sold my R2R in the late 70s, and have never thought of replacing it.
$800 for the 2 reel sets. Most are $400-600. Only a few hundred R2R tapes available for purchase new as far as I know. https://elusivedisc.com/music/reel-to-reel-tape/
A Studer A820 is going for $39k on Ebay... Of course there are cheaper machines out there.
These parameters are not fitting into my "sensible approach to audiophilia" and so the warm and musical memories of listening to a vast collection of R2R with my audiophile buddy will suffice.
Back when I was doing recordings for National Public Radio & others, I had a Levinson ML-5 which was a Studer A80 transport with Levinson electronics. Mark still owned the company then.
A bit later, I also acquired two 30 IPS Stellavox TD-88s, which I had modified. All three machines were 30 IPS, with 15 also available. Yes, there is an unavoidable head bump at a low frequency with 30 IPS, but it never got in the way of sheer musical immersion.
I made hundreds of recordings with these machines. There's no way that ANY vinyl - no matter how well it is produced - can compare to a 30 IPS master, or even a 15 IPS recording, IMO.
The problem that no one ever discusses (I can only assume that they are aware of it) is that these tapes start to lose their original quality after a few playbacks, and continue to deteriorate over time.
That being said, even if deteriorated over time, tapes are an astonishingly good source, but they need careful handling. I NEVER rewound a tape. Instead, I had another transport that would play the tape out - rather than rewinding it - thereby avoiding the print-through demon.
Because many of the artists were well-known, I never allowed Magnepan nor Apogee - both of whom used first generation digital copies of my tapes at CES - to even hint at the identity of the artists. They both won best-of-show accolades at CES shows. In no way am I saying that these master copies did it for them, but they didn't hurt, IMO...
30 & 15 IPS analog tape is better by far, IMO, IF it is handled & preserved properly. Even 7.5 copies are nice, but of course they are a pale shadow of the 30 IPS master, if it even still exists and hasn't deteriorated too badly..
The A820 Vs A810 is almost identical, the only difference being in the recording side. If it’s playback only, it’s identical. Most 810’s can be had for $10-15k fully refurbished, wired with external outputs, flux heads, etc. I own two.
There are also several other great brands and even the Technics 1500 from J-Corder sounds wonderful.
You can take things to the next level with a Doshi tape pre. There is discussion on another site regarding an imaginary system that’s been put together slower than the building of the Roman Empire with respect to tape pre’s. To me, there is Doshi and then everyone else.
Top notch R2R setups are expensive and there are certainly limited tapes available and they are very expensive. And not all are well recorded/saved. I can't recommend for anybody to get into tape.
But - the sound is amazing, simply amazing.
The only experience I have with R2R recently was with a Studor I believe in an all Boulder/Wilson system that sounded wonderful when listening via vivaldi stack. When he played “Master” tapes I couldn’t get past the hiss. Is hiss unavoidable in R2R? I kinda thought at this level R2R would be quiet? Also lack of source material I like is an issue. For me that’s why I’ve never considered it.
George
George
George, the hiss of tape is there with digital (from tapes) as well, but excessive hiss on R2R playback can come from many sources: bad caps, caps going bad, dirty tape heads, bad tape heads, etc.
With a copy of the master tape, you are closer to the source - in many ways - good and bad! But once heard, there is no substitute.
But tape is really for those passionate about it. If someone thinks vinyl is a PITA, they should never consider tape. Demagnetizing, cleaning tape heads with a small Q tip and 97 pure alcohol or a specific cleaner, setting EQ to match the tape, maintenance of the heads, replacement of caps, etc. Lots more care and feeding. But the payback is ahhhhhhh, so good!
ok; so i own 3 Studer A-820's so i am biased. but you are off base on your A-820 <-> A810 compare. it much, much, much more than differences on the record side.
and A810 is considered a broadcast machine, and the A-820 is a master recorder. other master recorders would be the A-80 and Ampex ATR-102. master recorders have a much more refined tape path, and much more robust chassis. which basically relates like a turntable and tone arm to refinement.
the Technics RS-1500 is considered a prosumer level tape deck. the right one with good output electronics makes a fine playback machine. i've owned a pristine all stock RS-1500 and a really fine sounding RS-1700 modified by Tim deParavicini (Tim, who recently passed away (RIP), is who modified the tape decks for MoFi and the Tape Project).
i'm not saying that an A810 is not an excellent choice for playback of tapes in a high level system. it is very very good for that. but assuming both machines are in similar levels of tune, an A-820 would sound better like a better turntable sounds better. how much better? some would pay for the difference, other maybe not.
as far as Doshi; a fine product but not my cup of tea. i would prefer the tape repro i own, the King Cello. and others to consider are mostly bespoke custom jobs. the best tape pre i have heard is a modified set of output electronics from an Ampex MR-70. or the ATR Services Aria.
Mike, you’re off. The 810 and 820 have the exact same playback mechanism. It’s all in the recording side the differences.
And for playback only, the 1500 Technics is excellent, especially rebuilt by J Corder.
From Ki Choi: “both share all the same audio electronics. The power supply section is a bit different between the two models but not by much.”
The 820 has a much better recording section, and the A80 beats them both all around.
hopefully readers will do their own research and come to their own conclusions. for clarity; Ki Choi was referring to the audio circuits and not the mechanicals when he mentioned 'same audio electronics'. i use custom output electronics. particular models of the A-80 have specific output electronics that some (but not all) prefer to the stock A-820; but to just post a blanket statement that the A80 is better is just not informed. it's not that simple.
Ki is a local friend for many years, works on all my decks. we have discussed these issues many times. certainly there are others with lots of opinions too.
