Ever see a Dim Bulb Tester?
Twisted
Better known as a poor man's Variac?
Just wanted to share, I have made about 15 of these recently.
I have never seen a DBT this compact, portable or this small.
Just use an old computer power cable, throw it in a drawer.
Craigslisters dream..
Would not be hard to make yourself.
Click the pics to enlarge......
These may be better suited in the DIY forum, but if you need to burn in a power cable or two (put an IEC input on each side or burn 4 cables with the dual receptacle box) or as a extention box with killer internal wiring (buy a foot of some really good stuff), and killer receptacles and IEC input, they make for an excellent power extention box.:D
A good power cable burner to burn em/reconditon them, is a very handy thing to have laying around, especially if you have a good recipe for burning them in!:D
Even easier to make!
Double box, plug on one side, and switch on other.
:woot:
Should work good with the variac I have
Here's mine. I built it to test my Carver TFM-25 after replacing some smoked components. (I'm not experienced in fixing blown amps, BTW). The inrush of current when I powered the amp up lit the bulb brightly a couple of seconds, and then dimmed back down as the big power supply caps charged up-- just like it was supposed to-- it was very re-assuring.
Jazzman53, that looks pretty spiffy, is that basically a switch connected to the bulb, bulb to a transformer and the transformer to an outlet? If so what are the specs on the tranny, if I may ask?
Ok, be that way!……………it’s just a simple question. :)
By the way, I just built one, and to test it I have to get a 60 watt incandescent bulb, no led’s. It’s been a week now and I’m still looking for one!
Hey sorry about not replying. .Somehow I completely missed your post, and I almost never check the forums these days. There is no transformer, there is only the resistance of the bulb limiting the current flow.
Oh, ok no problem, I meant to put a smiley face at the end!
Here’s mine with a 60 watt bulb I just got. Only incandescent in the store!
