Ethernet isolation
Dizzie
Sacramento
After grounding all my electronic chassis and speakers using Shunyata products and finding a tremendous improvement, I am now wondering about Ethernet treatment.
I use an Aurender N30SA with all music files stored internally. I do not stream. I only use the Ethernet connection to control via an iPad. The Ethernet connection to my router is via a long CAT5e. The cable runs in my attic and down an outside wall inside a metal conduit.
Is there much for me to gain by using an isolation device? If so, I would appreciate recommendations. Thank you.
