I bought the DEQX PreMATE in September, 2014. IMO, it's an amazing product that solves many speaker and room problems.
I happen to believe in the theory of speaker time coherence. It's the driving principal underlying Vandersteen speakers. The DEQX corrects for time alignment issues that are inherent in most (if not all) speakers that use high order cross-overs. As an fyi, Vandies use 1st order cross-overs.
Perhaps the biggest improvement derives from room EQ correction which is effected by using a mic at the listener position. I cannot overstate the deleterious effect my crummy room had on my rig. The DEQX tamed my room and speaker problems. The main improvement is that my speaker operate more like a matched pair and have a more level FR. Soundstage, imaging and the like are just fantastic. It's hard to believe that I got so used to listening to such a blurry soundstage and a washed out sonic presentation.
Perfect?? NO! Tamed?? Yes.
IMO, one could have the most expensive high-tech rig, and own speakers costing 6 figures .... and if the room is crummy, you've tossed a lot of green down the receptacle.
P.S. Unless one is a real computer savvy tech head, I strongly suggest that they use the DEQXPert (a real person) to remotely configure the DEQX using your own PC, ... assuming you spring for the DEQX.
Bruce
