gadawg
- Jan 17, 2017
You've lived with your D-02X for a while and no doubt gotten it well adjusted to your ear and your system. I have a K-01XD (coming from a K-03X), and it's taken me a while to understand this unit and get it anchored into my system for my music. The DAC section of this unit is very similar to the N-01XD, and IMO it's new discrete component DAC technology is a big step up from the chip-based DACs in Esoteric's prior units. That said, the new filter and up conversion settings in the XD units can have a significant impact on what you hear - tone, detail, sound stage, etc. So I'm wondering if the N-01XD you heard really got a fair shake relative to DACs you've lived with. And if heard the same way with the same settings, like you, I'm wondering if a D1X or D1X SE's house sound will differ substantially.
A little history here might help ... before I bought the D-02X I had originally bought the K-03X then upgraded to the K-01X and never quite got happy with the size of the soundstage. However as I moved up the Esoteric line the soundstage became larger with more space and air. I noticed that more so than any change in timbre or tonal qualities as I moved up the line. In fact, it wasn't until I heard a D-02X that I was blown away with the sound. The D-02X design wise was closer to a single box D-1 than an upgraded K-01X or N-01 and it really checked all the boxes I was looking for at the time. That said ... even then I had heard a Vivaldi stack and while I liked it better wasn't in a position to spend that kind of money. So, I bought the D-02X and have been quite happy even when comparing that to my now sold-to-a-friend vinyl rig. It was after I bought my R2R that I decided that I wanted to upgrade my Digital front end as the R2R has created such a large gap that I was struggling to enjoy the digital front end. So, with that in mind I wanted to hear the new discrete DAC and I've had a chance to listen to a couple of models in my system at this point. They all have wonderful tonal qualities that I do like better than my current DAC but like before I am finding that as I listen to the progressively more expensive Esoteric DACs that the size and scope of the soundstage grows with it and is something super important to me personally. And yes this is personal preference and not an indicator of quality. So, since there isn't a D-02XD nor am I thinking one is coming, I am expecting that to get the sound I'm looking for I'll need to go all the way to the D1X SE if I stay in the Esoteric family of products. That said if I'm going to be at that price range then I will compare it to other comparable products from DCS and Wadax as well. I mentioned that I already bought the Rossini Apex and I did but its long term use will be my for my headphone setup.
As far as settings go .. the D-02X doesn't have the normal number of filters that could be changed as some of the other Esoteric dacs do so I can't say that its settings would be comparable but I can say that I did ensure all oversampling settings were consistent between models I compared. I also noticed that the newer models have different filter choices as you move up the line .. but for the most part I preferred the default settings and did most of my comparisons there.
What I am hoping to find is a DAC with the tonal qualities of the new Esoteric discrete dacs, the detail and layering that I'm hearing from the new Apex line of DCS DACs and a soundstage that blows out the walls of the room. I'll certainly update this thread once I hear some of the other DACs and its also possible that after I've swapped out my BAT Rex gear for the VAC Statement gear, my preferences may end up being totally different.
Cheers and thanks for going on the journey with me!
George
