Michaels HiFi
OK guys - looking to upgrade with a 1 meter ethernet cable.
What are you guys liking in the under $700/meter price range?
in case you want to get better sound from streaming respectively efficiency from what you spend, then skip the e-cable until you did everything else.
invest in a switch, then vibration control for the switch, then powercord for the switch.
even once you are done, the e-cable wont be the icing on the cake...it will be a rice grain among many.
