Cool tube gear from Line Magnetic ...
joeinid
Super Moderator
NY
Here are some amps I would love to hear.
518 IA
  • 2 x 845 / 2 x 12AX7 / 2 x 6L6
  • Tube rectified with a 5AR4
  • 22 wpc Single Ended
  • 4 line inputs + pre amp in
  • 4, 8 and 16 ohm speaker terminals
  • Point to point wiring throughout
  • Remote control volume with mute button
  • Tube cage
219 IA
  • 2 x 845 (output tubes) / 2 x 300B (driver tubes) / 2 x 310A (input tubes) / 2 x 12AX7
  • 24 wpc Single Ended Class A
  • Adjustable bias with built in meter
  • 4,8, and 16 ohm speaker taps
  • Two power transformers for a true dual mono design
  • Tube cage
For the money they are great value. The Gold up top & their tube dac sound way better than expected.
probably but I was thinking going efficient with the monkey O96s ( obviously the orangutans)
Ooooooooh, even better. I can not stop thinking about this gear. Those 0/96's look really nice. I hope someone hear has heard them.
Orangutan O/96
With the Orangutan O/96 DeVORE FIDELITY brings it's award-winning blend of musicality and accuracy to a new speaker designed especially for low-powered tube amplifiers. 10" paper cone with a phase-plug powered by a motor adapted from our Silverback Reference drivers. 1" silk-dome tweeter with a powerful double-magnet motor system gently horn-loaded.
[TABLE="width: 94%, align: left"]
[TR]
[TD="width: 35%"]Frequency bandwidth:[/TD]
[TD="width: 65%"]25Hz-31kHz[/TD]
[/TR]
[TR]
[TD]Sensitivity:[/TD]
[TD]96 dB/W/M[/TD]
[/TR]
[TR]
[TD]Impedance:[/TD]
[TD]10 Ohms 8.75 Ohms minimum at 190 Hz[/TD]
[/TR]
[TR]
[TD]Dimensions:[/TD]
[TD]12"d x 18"w x 35.5"h (including stands)[/TD]
[/TR]
[/TABLE]
Good choice!! Heard them with some arc gear. Midrange & vocals are very lush & a very strong quality in them. A good way to put it would be if you want the warm midrange of panels with that box speaker energy
I've heard the 0/96's a couple of times at my favorite dealer. The first time was in a large, acoustically treated room with a Shindo Preamp and Monos. It was all jazz being spun on the Shindo TT, and that system was making great music. I don't remember how wide the soundstage was, how dynamic it sounded, or how clear the highs were; I just really enjoyed the music. No one in the room could sit still, we were just several dudes with tapping toes and bobbing heads. I bought 2 of the albums that were played that day (Count Basie - Basie Jam and Tsuyoshi Yamamoto trio - Autumn in Seattle).
The second time I heard them was in a much smaller room in a nearfield setup with the little Shindo Apetite integrated. They sounded good, but I think they need a bit more space to show what they're all about. The music was a little to forward for my taste that day...
If I decide to try something new, I will be giving the O/96's some serious consideration. My dealer carries the Line Magnetic gear as well and I bet the O/96's would sound great with it.
Have I mentioned that I own and LOVE tube amps? LOL...My Avatar is my 90wpc Velleman (customized by ME) ..but I love little 10 watt console amps too !!!
Jay, love that tube amp for your Avatar...the Ayon III right ?
Here's a shot of my Line Magnetic 218. I'm in love with this amp and can't imagine the sweet sounds that the huge 219 produces. I would really like to hear either the O/93's or O/96's but I live in an audio wasteland. The dealer I go through, who does the trade shows with John D., thinks the O series sounds better than the new Gibbon X. I really like the O series of speakers. They remind me of how speakers looked when I was growing up which I think is pretty cool in a retro way.
I also like this little amp.
Mini 218
2 x EL84 / 2 x 12AX7
3 wpc Single Ended Class A
Headphone output
One input
4 and 8 ohm output taps
Tube cage included
I think this would make a sweet headphone amp!
At one point I had the web address for an inside look at the Line Magnetic Factory. I'll have to do some rummaging around and try to come up with it. If I recall correctly it was in Chinese but had some pretty cool pics. Stay tuned!
Hi Doug,
I wish I had known about the LM amps before I bought this one. A Miniwatt N3. It's not terrible but it's a little flat.
Mini 218
Headphone output
One input
Tube cage included
Yep, it's my Ayon Spirit III. I love it. Here's a pic of my rig. Ayon tends to fly under the radar a bit, but they make superb gear. The Spirit III weighs about 75 lbs!
Nice rig Jay. I dig those speaker stands. Are you starting to peel the veneer off the shelf above the Ayon with all the heat it puts out?! :P
Thanks - the stands were designed by Carl's (Nola designer) daughter to go with the Micros. There are 4 ball bearings between the speaker and the stand. I hadn't thought about the veneer under the media console, but it looks fine...whew! I felt it today after having the amp on and it was warm, but not hot. Hopefully it doesn't become an issue with time.
